ARB Air Locker leaking oil
welndmn
Welndmn and all,
Thanks. Welndmn, I understand from some of the comments to disconnect the air line on the differential side means taking the whole rear end apart?
Vent is for sure first thing I’ll go through.
Nope, there is a big brass fitting with a spring on the top of your diff. You will see the compression nut and just un screw that.
N
NorCal1971
All, thanks so much! So rubber vent hose and the vent fitting at the differential were blocked. I cleaned the vent. Then disconnected ARB line at both ends blew it out and used a little brake cleaner. Everything seems working now. Is all cleaned up. I’ll watch and make sure it doesn’t come back. Thanks again!
nvrstuk
Glad you got the vent cleaned out...you should be good!
