I recently put '98 explorer efi /mustang harness on my 302. Runs awesome, way better than it ever did with a carb. Fuel rail doesn't hold pressure when off though. Normal fuel pressure with key on,engine off (40psi)and key on engine running (30psi). When turned off, fuel pressure drops immediately. I did some tests and if I pinch off the return fuel line right before I turn the fuel pumps off, it holds pressure fine. Am I right in thinking that this points to the fuel pressure regulator and rules out the fuel pump and injectors as the culprit. I'm bummed because I replaced the original with a new one just to avoid this type problem and threw the old one away. How big of a deal is this if the only problem seems to be not maintaining pressure when the engine is off?
