badshoe
Introducing BadShoe’s Ford AODE/4R70W air test plate. This tool is used to verify clutch, band, and accumulator activation on the AODE/4R70W-75E family once the tranny is assembled. The kit comes with an 8x13- ¼” 6061 alloy test plate, twenty-one stainless steel hold down bolts, two line-up studs, gasket and instructions. I have added a “peep” hole in the plate so the OD band application can be observed. By using this tool, you can verify the integrity of the piston seals and slip rings. This will give you peace of mind before bolting in the valve body and finishing the build. Email me if you have questions or check my web site for details.
www.badshoeproductions.com
