- Mar 28, 2012
- 3,542
try a heat gun and scraper for your glue and deadener under the dash.
might want to consider a good sealant to paint into your seams before you get into your bodywork.
www.buykbs.com makes some great products that will help your project out and keep it around for the next 40.
kbs also makes a spray "cavity coater" that works well for shooting inside panels.
Thanks Nick! Your work is an inspiration for me, and I'm probably going to "borrow" some ideas from your interiors. The deadener and glue actually came out with the media blasting even though they told me it wouldn't take the glue off. But there's a ton of black goop on the seams. I've actually used KBS on the frame, and am adding ceramic microspheres to their RustSeal primer that I'll be doing the underside and inside, and inside the top with before I do a final DP 40 and top coat. I'm going to prime the underside and inside but not the rockers with KBS, and prime the outside with DP40 just so I can get the metal covered. I want to minimize any flash rusting before I start on the bodywork. My understanding is that I should put the primer down BEFORE I put the new seam sealer in. That way all the metal is coated under the new seam sealer. That should keep the rust away from my freshly cleaned metal. Their cavity coater is interesting, but I think it's just a wax you can spray into the drain holes. I'm going to use their rustseal primer on the inside of the new rockers before I weld them on since I'll have access to them. Then when it's all together use the cavity coater for insurance in case the heat affects the primer. I was pretty happy with the RustSeal on the frame so I think it will work great on the inside and underside.
