- Nov 28, 2011
- 784
Thanks for the responses Paul! I think you’re on the right track based on new information.
I found a piece of the rear harness where it looked like someone had tried to wire in trailer lights. It was a mess. Cleaned that up and it cleared up the ammeter jumping like crazy. So the new situation is this.
I have park all park lights! Fixed something.
Hazard switch does nothing (it at least did something before I started tearing into stuff)
Headlights and taillights in the headlight switch all the way out position work as well. These didn’t work before.
No brake lights.
No front driver turn signal at any time or any combination of different switch positions. This worked before I started pulling stuff apart.
I think my front turn signal problem is all linked to the yellow w/black wire but I still don’t see where it is supposed to go. The “left” side of that wire comes out of the two prong plug on the turn signal switch and goes out to the turn signal. I didn’t find any issues on that run.
The part where I’ve found the loose end discussed above comes out of that factory splice and I have no idea where it should go. My gut says headlight switch but I don’t see a spot for it. Like I said the front driver turn signal worked before I started messing with things so I’ve pulled that wire out of something I believe.
Too long didn’t read: No brake lights and no front left turn signal now.
No brake lights.
