- Nov 3, 2003
- 47,732
Yep, the snowball effect is in full force with Broncos!
Did you say you measured your current lift? Checking between the top of the axle tubes and the bottom of the frame rails? If it's more than 3.5 that's even more reason for a low caster reading.
You could have 5" roughly on a dropped pitman arm, but it's rating is less than that because there is a little bit of drop even on the stock arms.
