Currie sells 9 inch large bearing tube ends for about $70 a pair. How hard can it be to cut the small bearing ends off and weld these on?
I have a portable ban saw I can use to cut the ends off, make sure they are true, bevel the ends, bolt the ends on to the new axles to keep things straight then tack weld to prevent bending before finish welding?
Do I need a $250 alignment bar jig to weld these on? After all its my trail rig but I don't want to do a bad job.
My goal is to convert it to a large bearing then install 35 spline axles and truss the housing. I do have a 240 volt Miller MIG to do the job.
Is it worth it or just I just pick up a large bearing housing.
