fredc
So I have a question for any knowledgeable souls out there. I have a 77 Bronco with a mid 90's Mustang 5.0 and a mustang hydro boost brake set up. I am wanting to convert to a Tesla electronic brake system using a bosch ibooster. So the question I have is about switching out the Master Cylinder. The one that comes with the ibooster has a 1 inch bore. I have disc front and rear and need a 1 1/8 inch bore Master Cylinder. I have a Welwood MC with a 1 1/8 inch bore. the mounting holes on the MC are oval so it will bolt up to the ibooster brake booster just fine. It just needs to be clocked about 45 degrees for the new MC to be level. The only other issue is that I need to fab a push pin for the booster push rod to make conatct with and be flush with the new Master Cylinder plunger. Does anyone see any flaws in the idea? I should be able to switch out the Master cylinder? Correct. All the Electric vehicle forums do not talk about switching out the MC.
Comments and feedback welcome.
As part of this I am also switching to a Volvo Electric Power Steering pump. But that is very straight forward.
thanks Fred C
thanks Fred C
