Hi Everyone,
I am working on the '70 build, trying to clean it up for sale. One of the things that I would like to correct is the orientation of the steering wheel. Right now it is too far in the clockwise direction (probably by about 40 degrees).
I removed the Tom's steering wheel from the adapter hoping that I could just rotate it back to the next set of holes. I would have been off by almost as much in the counterclockwise direction.
Just for reference, it is a Tom's Bronco steering wheel, and Ididit tilt column, and a Borgeson lower shaft and joints.
So, I think these are my choices:
1. Remove the adapter from the upper steering shaft and rotate it back clockwise and align it on the splines at that orientation.
2. Remove one of the lower joints (probably at the steering box input) and change the orientation there.
3. Drill and tap new holes in the adapter.
Just wondering if others have found one way to be a better solution.
Thanks for any input.
Take Care,
Jeff
Take Care,
Jeff
