does anyone know of a company that makes output yokes or flanges for a dana 20 with 1350 or bigger? ive got a supercharger on my bronco and am prone to Granading driveshafts.
I don’t think the output shaft would support needing a larger yoke. The output shaft itself can barely survive with the 1310. Probably time to think about putting in a 205.
ya that makes sense of course. just i am building it for a client and it has about 425 hp and has a 5 speed transmission. so the 205 would be a pain to achaive after everything ive done to get the dana 20 and everything to work. i found a 1410 yoke. im gonna either try and make a 1350 driveshaft with a 1350 to 1410 or just do a 1350 driveshaft and use the stock 1310 on the t case side... hell probably break other things before that. hes NOT offroading it
If you have already put a 32 spline output shaft on it, then just get the 1350 cv flange.
If your still using a stock output shaft, buying anything is a waste, the output shaft will snap.
