Is there a good tech write up on removing gear set and installing new set? I have some help setting up the new set but I never removed gears before.
I made set up bearings using bearings from o'rielly's. Takes about 10 min per bearing to hone them out witha drill and a drum sanding bit from harbor freight. Make sure they are the same thickness as your final bearings or its a waist of time.
Thanks guys .... my son is going to teach the old man something this time. He has had to opportunity to work at an local EB shop so he his learned how to set up a few gears sets . I have a HF press which hopefully will get the job done. I’m going to start tear down this weekend.
Well Shit ... setup bearings.... dam. I guess I will have to ask around. God this looks like it’s going to be a PITA
