The early Bronco used a small U-joint, The heavier shaft can be swapped in from the chevy short side dana 44 with the larger U-joint. the heavier long side must be cut down and resplined or made from scratch. the f150 and 78-79 Big bronco short shaft can be used but the spline needs to be under cut and the spline is a little short. some were OK but some were not I bought my oversize shafts from Currie back in the day. they are much more available these days than 30 years ago. they are cheaper now new than cutting and re-splining we use to do.
