Silverhorse
Thanks for all the info guys. I'm getting another door from a friend to try, it has new hinges on it. See if it lines up any better. Then adjust the body mounts some more. I'll give it another shot tonight!
Well the other door and hinges made a big difference. And I didn't even adjust the body mount yet.
I'm going to order new hinges, probably the removable type any input on hinges?
Boy for such small hands you do good work on your bronco!!
Silverhorse, From the looks in the pics the body mount behind the pass seat is too high, however I can't see how the front or the rear of the Bronco sits, also as another stated, the door needs to drop down to line up with the front fender.
1: Make sure that the body sits level on the frame, front and rear, measure from the bumpers, if you have them installed, or the frame ends to the bottom of the body, if not level you may have to add shims or cut from the bushings.
2: once the front and rear is where you want it line the door with the front fender and work your way back, you may have to add or take way from the bushings, except for the ones at the front and rear these need to stay fixed. This will tell how good you lined up the replacement panels. Use the body lines along with the gaps around the door as a judgment mark.
You have some work to do its just gonna take time. Step back, look at the whole rig, make a plan and start out fresh.
I wonder if raising the rear body mount would help. I have seen sag occur there as well which would open up the top part of the door opening. Does the opening measure as normal ??
If you need to change the bottom line without changing the door gap this is what I have seen work. As Rick said, shim both seat and rear body mounts.
Silverhorse,
I just replaced the same body parts and ended up with the same issue.
Turned out to be that the floor support that your body mount attaches to had sagged on the outside where the front of the rocker attaches.
I used a big bottle jack to push it up. I pushed it above square to give it some pre-load and welded everything back in place, and the gap issue was gone.
Not sure you have the same issue but in reading one of your posts you said that the body mount was not touching on that side and mine was the same way.
I also put some pre-load on the bottom of the door post by putting the bottle jack from the front tire to the front side of the post. No matter much I braced the DP pryor to welding it would drop when I tried to fit the door. You may try just cutting the DP loose at the bottom and pushing the bottom back before rewelding. This will bring the back of the door up and as long as your rocker is square the gap should come in good.
Hope this helps.
Two possibilities: 1) top door frame is bent in, probably not. 2) Rocker and door post are too far out at bottom, most likely with work you have done. Front fender will follow them in. You have had a lot of things working against you since your first welds. Not being a smart a**, just stuff starts with one small thing off and keeps building off of that.
