Hey - thanks for the good information. I like that the primer is grey and the Chassis Coat is Black - that should make it easier to get the coats uniform. I am very interested in it taking 60 minutes between coats. If you did it at that pace, then you shoot this (2 coat primer and 2 coat finish) in 1 day. I thought it would take 1/2 day between coats making it a 2 day process
Did you put plastic on the ground under the frame?
How much of each product did you use on the frame?
How long are you waiting until you start the chassis assembling?
If tarping off the area works, that would save me a ton of time vs. masking off my entire garage, sealing the seems, using ventilation fans, body suit, and all the other things for making a paint booth. Maybe I need to do the paint booth masking just on the final paint job and clear coat(s) process.
I am doing the chassis, brake pedal, gas pedal, e-brake, and the bottom of the tub at the same time to eliminate cleaning up twice. I think I will be shooting in 70-75 degree weather.
You may have saved my whole weekend! Thanks again for all the advice and inspiration!
