- Nov 3, 2003
- 47,691
I would think something like that could work. I'm still baffled as to why you're getting liquid out of the vent though. Is it possible that you're venting at the return port instead of the vent?
I don't even know if that's possible, or if there is a difference really. But I think the vent is open only at the top, while the return has a tube that extends down into the fuel. Once you are getting near full, you'd have fuel potentially getting pushed up into the tube and out the port.
Ok, nevermind... I realized the tank vent is the rearmost port, well away from the return line and pickup lines, which use AN fittings.
Must be something literally deflecting the incoming rush of fuel into that port and back up into the system. Strange.
Here again though, if you mount your canister up high enough, even liquid getting into the tube at the tank should not be able to flow all the way forward and up into the canister.
Then again, on a long steep downhill climb with a full tank...
Good luck.
Good luck.
