gunnibronco
I'm replacing my rear JD/JB6 calipers (3") with 76-78 Eldo calipers(2.5"). I won't be using the e-brake function. I just need a smaller piston caliper to fix brake bias issues.
A few questions:
Will I need to adjust anything or will they act like a normal caliper piston if I don't use the e-brake? The instructions that came with the calipers state the e-brake must be properly adjusted, and regularly readjusted to get a good pedal feel.
I'm planning to use the same pads I have in the JD/JB6 calipers. I see where the Eldo calipers have a notch and there are specific pads for these calipers that key into the notch. Will using the JD/JB7 pads work ok since I'm not using the e-brake function?
A few questions:
