mkaenel
I have decided to do a thread on an engine rebuild from the ground up. Currently the engine is stripped down to block. The engine took a dive after about 300 miles of use. There were pieces of metal bouncing around in the engine and two pistons were destroyed. It was a crate engine when I bought it and was quickly turned into a paper weight.
So here is the first post of the build from the ground up. Please feel free to post questions/comments.
Breakdown Details:
302 built to 330hp/330 lbs torque. The engine was torn down to block because I was chasing wear issues and other problems.
1. Heads removed and checked - There was leaking valves in the number 3 and 4 cylinder. All was repaired at the machine shop.
2. Rod bearings - There was uneven wear on a few of the bearings so the first thought was a bad crank. The machine shop checked the crank and it was fine.
3. Engine block - sent in and line checked. It was not a perfectly straight block and was machined to be perfect.
So far I am about 600.00 in and I still need a new set of KB forged pistons. The total bill for this rebuild will be about 1,200.00 in the end, but I will know what I have in the end.
I do have to thank the Paris family (The Nik's and Alex) for all their help with this rebuild. Without them I could not have done it myself.
Matt
Breakdown Details:
Matt
