engine runs wierd
jperry1290
So I recently tossed my oil pump shaft in to the pan. After replacing it my engine jolts a bit and It is in rhythm with the firing order(1 jolt, 2 jolts,1, 2, etc). There is no grinding sound and everything else appears to be fine. The oil pressure stays constant. Could it be a ignition problem or maybe the cam and distributor gears are messed up? The dizzy gears looked fine when I put it back in.
phred
Earth
How long did it run with no oil pressure? Did you have any metal shavings in the pan? Are you sure you have the dizzy back correctly? It could be off 1 or 2 teeth on the cam gear forward or advanced.
Just tossing out ideas.
jperry1290
jperry1290
I found that my num 7 spark plug wire was bad. When I replaced the plugs I noticed that the po had the wires 180 off on the dizzy. I routed the wires correctly, put num 1 at tdc, reinstalled the dizzy and now it won't start
You verified that number one was at TDC with the spark plug out? Or just with the marks?
jperry1290
jperry1290
verified the tdc on #1 2 x's with the spark plug out and coat hanger in the hole. i also checked the rotor 2 x's and verified it was on the #1 tower. all i get is a backfire
