- Sep 20, 2018
- 308
After several months I finished rebuilding the entire steering column, new hydroboost with new saginaw dual return power steering pump, all brand new brake lines with brake speed bleeder screws, electric fuel selector switch, 23 gallon Aero tank with a sending unit from a member on here for the 23 gallon tanks.
I have a couple questions and issues I would like your help with if you have had these issues and overcome them or if you know what the issue could be by the explanation (I know it is impossible to "diagnose " without seeing/hearing/feeling what's going on so I will do my best to describe the issues and provide photos (let me know what you need to see.) Let's get started;
1st- Previously I had a vaccum assist power brake system, so I just installed a brand new hydroboost system with a saginaw dual return power steering pump (I am still running front/rear drums). I followed all the instructions on bench bleeding the master cylinder and "burping" the power steering pump.
When I test drove the Bronco it felt like the steering was very tight/ sticking and had to fight to steer the vehicle, but when I hit the brakes the vehicle stopped (very happy the brakes worked). I have never driven a vehicle with hydroboost so I am not sure if what I am feeling/experiencing is normal or if there is something wrong?
I explained this to one of my friends who has hydroboost and he mentioned maybe I had the high pressure and return lines mixed up but then said that if that were the case i probably wouldn't be able to stop.... . Is this a possibility?
2nd- I have a separate thread going regarding this but I installed the electric selector fuel switch and also installed a new OEM style toggle switch (my old toggle switch was old and hard to toggle.) I connected all wires according to the diagram provided. I filled up the aux tank and the switch reads full but when I toggle to the main tank the gauge goes to empty as if the power is off (I know there is gas because I just put in 10 gallons).
I tried to do my best describing everything.
Thank you in advance for your time/help,
Sonny
Sonny
