Make sure you didn't bend the pin over on the small power connector - I have done that twice now by not being careful plugging it in.
Update - the Hand Held device will not power up in the cab but will when hooked to a computer. DirtDonk helped me sort out Grounding issues (Thanks!), but it looks like the harness that is a 2 connector from the TB might be bad. Fitech wants me to dismantle everything and send back (ugh).
Question - I wanna drive this so bad; is there a way to use my old Holley 4bbl Carb with the electric fuel pump that is in my Sherman tank? Or am I SOL? I thought even if I bought a different electric fuel pump made by Holley and used it instead of the submersed in-tank one, it might work, but not even sure if it would have enough suction to pull fuel through the in-tank pump.
Thoughts?
You can use a high pressure fuel pump with a carb if you use a return or bypass style pressure regulator. It bleeds off excess pressure back to the tank. You should already have a return line for the FiTech. Probably not a bad idea to have it in case you ever have problems in the future.
I don't think he meant using the return line to feed the carb. Even though it's low pressure, it's not regulated in that type of system. Like it would be on, say a stock Ford MPFI setup.
In this case you use a regulator that has an output that can be regulated down to carburetor psi ranges, and has a return line to bleed off the rest.
Probably the only type that can take 100psi down to 3-5 psi anyway, but I don't know that for sure.
Depending on the age of the tank/pump, it's probably in the (at least) 85 to 105 (maybe even as low as 60) psi range unloaded. The factory regulator throttles that back to 35-45 psi or so, and sends the rest back out the return line.
As you know, you'll need a regulator that can run that number down to 3-7 psi. Normally I would think you don't want to go over 5psi in general, but carbs like Quadrajets and (I'm pretty sure) Edelbrock/Carter carbs, would run better on 4 psi or so.
I'm sure someone knows for sure, or perhaps has even experimented with the different carbs at different pressures, but I don't remember that discussion.
This is the reason I bought mine. Real good support on line. KenI also found that Firech tech support was lacking. That are in a hurry to get you off the phone and not troubleshoot your issue. Fortunately there is a great Fitech oweners facebook group. The guys on there know more about the units then the techs on the phone at fitech.
That said, they do run great so don't lose hope.
Fi-Tech owners group is EXCELLENT - far batter than Fi-Tech's actual "support."
Read the stickies, be thorough and patient, they are very smart on there, but won't just feed you answers without you doing the homework first.
