377
Hello,
I'm in the process of putting together a new rear end for my rig. While choosing the components for my new third member I was given several options for a yoke and pinion support. The yoke options are both a short or long narrow 1310 yoke or a 1330 short or long wide yoke. The last option is a billet 1350 yoke. I'm familiar with 1310,1330 and 1350 u joints but, not really sure about the short and long parts. Does one yoke length have an advantage over the other?The pinion support options are standard, nodular iron,aluminum or billet steel. In the past I've just used standard pinion supports. Is there any reason to use one of these options other then standard? If anyone could give me some advice I'd greatly appreciate it. The rig in question has 31 spline axles with a Tru Trac Carrier and the engine has about 400 hp. It also has a C4 transmission with a Dana 20 transfer case. I haven't purchased drive shafts yet in case I went with a u joint other the a 1310. Thanks again for any help or advice you guys might be able to give me. Lastly the rig will see moderate trail use for the most part.
