Yeah, the rubber expandables will get you back home, but I would also recommend the brass ones when you can do them.
I've had two rubber ones blow out on me. Not fun. I don't like 'em.
The ones in the front of the head are the easiest to get to.
The back of the head are tricky with the heads on. They do make a brass or copper expandable that I've used on the back ones until I had the heads off and replaced with punch ins.
Some of the block ones are accessable. The ones under the motor mounts are impossible without jacking up or removing the motor.
Another good reason to make sure you are running the proper antifreeze to water mix. Antifreeze has a rust preventative in it.
I hate freeze plugs! I hope the one that went was on the front of the head. But take it as a early warning. Don't get stranded again, replace them with brass quality punch ins.
WHEW. Think from the long post I've been there...
;D
yep.
