I'm going to assume I have a rear freeze plug leaking but it seems to be leaking coolant between the trans (NV3550) and the bell housing adapter which is 3" higher than the engine to bell housing itself. I'm pretty sure water doesn't travel uphill to leak from where its leaking. It's been leaking for a while so when I replaced the heads last month I verified that it's not dripping down from above. No doubt in my mind it's the rear freeze plug just don't understand how it would leak out at the trans instead of the engine to bell housing? Thoughts? Guess I'll find out when I pull the trans out.... eventually, just not high on my list of fun projects.
