...i think i understood it would also work with a d44 if i ever go that route.
Correct. The parts used in the kits (a mix of Ford and GM-based brake components) will bolt to either a Ford drum brake Dana 30 or 44 front end. All the parts should swap right over to the 44 when needed.
It's the "Ford-specific" disc brakes from a '76 or later truck or Bronco that will
ONLY work on the 44.
Did i see i need a new master or can i use the original?
Yes and no. Depends on your preference.
You should be able to get away with using your original style master. Even with the larger-than-Ford caliper pistons, the extra pedal travel should be minimal.
However, it's very likely that your pedal will still initially feel a little "softer" because of the larger piston calipers needing more fluid to do the same work. Which will let the pedal move a little farther down that it did with the drum brakes.
Well, that's assuming that the drum brakes were adjusted properly in the first place! If not, then you might actually see an improvement in that department with the new setup.
The general setup for the larger calipers (whether the GM-based stuff, or the larger Ford "T-bird" calipers when doing the Ford swap) is to typically use a master cylinder with a 1.125" bore to handle the bigger piston volume. But this also pretty much dictates that you use a power booster as well. If not, you'll be getting lots of exercise for your legs!
So stick with the stock 1" master for now, and see how you like it. Just make sure it's all bled well, the calipers are mounted correctly (with the bleeder at the highest position), you ground enough material to fit, and do some short test drives to see how you like it.
There are a lot of members here using their stock masters with the disc brakes, but I don't remember hearing any definitive feedback on how they liked the pedal feel after the swap. Or if they didn't like it.
Anyone care to comment on that?
I am still using the stock master on my '71 with Ford disc brakes, and (I believe) a larger 1.125" master with a vacuum booster on the '68.
Both have good solid pedals.
Good luck.
