- Sep 24, 2010
- 2,863
Have a few questions on mating of the SS front disc brake hose to hardline as well as correct fitment to the bracket.
What have others done?
1. cut off and flare the larger fitting (7/16?) on the hardline and swap to smaller (1/4" ) fitting to fit the hose end or Use and adapter or other?
2. The hose end coupler doesn't fit in the stock (71) bracket. Change or modify bracket or change to a different hose? Are there different brackets used on the 76/77?
These are the SS front lines I have.
http://shop.broncograveyard.com/Stainless-Steel-Outer-Brake-Lines-1976-77-Disk/productinfo/12539/
And these are the hardlines I have
http://shop.broncograveyard.com/Front-Axle-Brake-Lines-Pair-Stainless-Steel/productinfo/12515S/
If the picture in the link is correct, it looks like these would be more correct (71.5 to 75)
http://shop.broncograveyard.com/Front-Axle-Brake-Lines-Pair-Stainless-Steel/productinfo/12514S/#
