[quote author=4byford link=board=5;threadid=14061;start=0#105719 date=1044529870]<br>I have a similar problem. I have a Tuffy console and the PO removed the e brake pedal assembly entirely due to interference with the cage. I haven't done this yet, but I plan get an underdash T-handle type E brake and put it under the dash on the L side of the steering column between the column and cage. These are available in the junkyard on early to mid 60s Ford trucks and 80s/90s small foreign pickups. To actuate, it pulls straight out on a ratchet mechanism; to release the T handle is twisted and then pushed back in. It lives out of the way under the dash when not needed. I will let you know what works when I get to that project...<br>[/quote]<br><br>I had that style on my Nissan truck and was thinking that if it was on the left side of the column that it may be in the way of getting into or out of the vehicle when the brake is applied, mine came out from the dash almost as far as the steering wheel did, and there is alot more dash on the Nissan then on a Bronco.<br><br>Just something to consider.
