Having a tough time here with a new set of Timken inner wheel bearings, Set 37 on my '76 D44 w/stock front disc brakes. New bearings from Bronco vendor. Passenger side went on fine but on the drivers side the inner bearing got hung up on the spindle. Tried to gently persuade the assembly with block o wood and hammer. Put up resistance so I stopped. Pulled assembly off(took some effort) and it left the seal and inner bearing on the spindle. Used a puller to get the bearing off - it went on @ 3/8" and came off pretty easily with the puller. Thought my spindle was the problem as it looked like it may have some issues. Ordered new spindle and another new bearing. Put spindle on and tried to see if the new bearing would slide on before installing in hub - again, no go. Tried the first new bearing for kicks and it wouldn't go either. Seems like the same issue. Both bearings seem to have the same degree of resistance. Any ideas here? Vendor was closed for the day but will try tomorrow.
BTW, I am not mixing up the outer bearing with the inner bearing(Set 45). Below are a couple pics of the old spindle, you can see where the bearing went on and appeared to smooth out some anomalies which is why I thought the spindle may be suspect.
Thanks,
David
Thanks,
David
