Throwing this out to the community to see if this sounds right. I have a 74 with a strong 302. The motor came with the truck and the seller said it had a cam but could not give me any other details. I have been driving it regularly for two years with no power loss (unless I go to high elevations)or engine issues. It has a Holly 570 street dominator carb (not a fan but it works well so why mess with it) Mallory distributor, OD trans, 3.50 gears and BFG 33" tires.
I do a lot of freeway driving and the truck seems to like to be at 70mph. At 70 the tac reads 2100 rpm. My OD gear does not kick in till I am going approximately 65mph and the tac is reading 2600 - 2700 rpm. I am able to keep it in OD when going up most freeway grades, but if I drop below 50-55 it will automatically kick down. It seems like no matter how I drive it I get about 11mpg everywhere. In the city or on the freeway it doesn't seem to matter. Is that normal? It seems like from other threads I should be getting better mileage.
I plan to install a Holley Sniper system in the future (when I can afford it) and my hopes are that it will get a little better gas mileage and perform better at altitude. I was also thinking that I might switch to a 32" tire. Any thoughts?????
