Gauge Cluster Mounting Question
Sak
Has anyone ever mounted the instrument gauge cluster from the
"outside-in" (cabin side) rather than from behind the dash? If so, what are the pros/cons, and how do you make it all look good cosmetically?
I ask because as I'm doing my rebuild it seems like I'm frequently having to pull the cluster as I am going thru grounds, sending units, etc.. Not only is it hard to get to, but I'm scratching up the paint on the dash and the cluster itself. I've got a full roll cage which complicates dropping the dash and I'm looking for an easy way around it.
Thanks.
sykanr0ng
It could be done as long as you are okay with it being really ugly with the housing showing and having screws pointing out at you.
I would guess that some sort of bezel cover could be made up to clean up the interface.
I wonder if the speedometer cable can handle the extra 1/2" of length?
The wiring would not be a problem, but not sure about the cable. Can't think of any other dire issues.
Have you ever tried to access the panel in place from behind, through the driver's side air vent? I hear you on the scratched paint (though that can be avoided sometimes too) but a lot of members find it easy enough to pull the vent and reach through the big hole it leaves.
Just a thought.
S
Sak
Thanks, Dirtdonk. Good idea on accessing it from the air vent. Hadn't thought of that.
Neither had I! But lots of members doing it, and then getting to do it myself once or twice on other people's Broncos, convinced me it's often a good way to go.
S
Sak
That's beautiful! Great suggestions to all. Now I've got a game plan. Appreciate it.
S
Sak
Quick question to gr8scott - where did you buy your connectors for the harness?
sanndmann3
I've bought similar ones on ebay. try searching for metri pack. can get from 2 to 10 conductor, maybe more...
Skiddy
makes it so much easier to get to the speedo cable too
gr8scott
When I did my rewire I bought this kit from Summit. Pricey, but well worth it. I use them all the time.
My local Napa has individual pieces, connectors, pins, seals, so you can get exactly what you need.
The AAW harness that stock orange linked to is literally my favorite harness. It's not for someone that wants a harness to practically install itself, because it leaves the installer with more decisions to make than most. But it has so many options and a great fuse box, that it's got a lot of potential for the custom vehicle install.
And middle-of-the-road-ish price wise too.
Where did you end up mounting your fuse box stock orange? Got pics?
