- Aug 28, 2011
- 477
Just threaded into the plastic but it's pretty tight. I didn't get a lot of miles on the engine the last time around (before I broke a piston) but for what time it did run I didn't have any leaks, nor did it leak for the few years it sat holding fluid. When I was building my Power steering/ Hydroboost setup a few years back there were several people using this successfully.
It was the easiest/cheapest option for me so that's what I went with and if it leaks eventually then I'll be looking at other options.
It's the low pressure return so high PSI not an issue nor is backing out with my braided hoses secured to the fender.
In my opinion the wild horses reservoir looks the most bullet-proof (but is pricey), The explorer reservoir can be made to work for the cost of a fitting (but looks like it has more potential to leak than the others), and the super duty option looks nice but requires a little more effort to mount.
-Seth
-Seth
