bronko69er
EB Addict
Ok, I just had a long chat with my car guy here at work (fellow ME) and we came to this conclusion:
For those who installed a higher temp t-stat, this is what is most likley happeneing. By putting in the higher temp t-stat, you are increasing the flow restriction whereby increasing the pressure in the motor. If the pressure is increased, the temp at which the water will boil will increase as well. As long as the water is not boiling, it will remove alot of heat from what it's in contact with. As soon as it starts to boil the metal temp will climb. This is why we add coolant and the system is pressurized, to keep the mix from boiling. You engineers may remember that the specific heat of water vapor is far smaller than that of liquid water.
Adding flow restriction or some other means to generate pressure, will go a long way in promoting heat transfer....... More to come. Saty tuned, Gotta go crack my thermodynamics book.
