Hello all,
I’m seeking some advice on a problem I’m having with getting my Bronco into 4WD.
I have my rear drive shaft off and want to pull my Bronco out of the garage to turn it around.
I’ve got the front axle shifted into 4H with hubs locked, and the rear also in 4H (again no rear drive shaft) on my twin stick D20.
All should be good to drive, but when I let the clutch out the truck doesn’t move and I can hear a rhythmic ticking (light thumping?) noise coming from the front.
Any advice on what I should check, try, look for?
Thanks!
Thanks!
