I need some more travel from my Driveshaft.
Ford 9 inch center section front axle. Dana 60 ends. Standard width. Brand new Tom Woods driveshaft.
I have 3 link in front and coil overs. When I install the new shaft I notice it binds up with about 3-4" of down travel in suspension. I have limit straps but don't want it that tight. Low pinion front. High pinion would be really tight to pan and others. I am sure that this is how my last shaft was bent.
I there any good high angle drive shaft or CV joint for this. My pinion angle is within 1 degree at the diff and is about 11 degrees up at ride height.
