SavageBurro
- Aug 12, 2013
- 588
*SALE PENDING* 1976 ford high pinion (hp) dana 44 front straight axle from f150 4x4. My build went another direction. I believe it has stock 3.55 gears. Never had the cover off but everything turns smooth. Both axles turn the same direction when spinning the pinion so maybe it has limited slip? Has lots of surface rust but should clean up nice with a wire wheel. Be great for upgrade from low pinion dana 44 or dana 30. Calipers definitely need replaced. Rotors look good but might need turned - not sure. Forgot I borrowed one of the locking hubs off of it so it is missing one manual locking hub. These have the more desirable weld-on wedges, not the cast ones - making it easier to modify if so desired.
