Driving the truck last night I noticed sparks coming from behind the steering wheel occasionally. After further investigation the top 12V power post for the horn bends a little when making a right turn causing it to come in contact with the turn signal cancelling cam on the steering wheel. Since the cam is grounded I believe that is causing my short. After correcting the steering wheel back to center the horn post corrects itself and sticks straight up again. I tried loosening the steering wheel because I thought maybe it was causing too much pressure on those horn posts. That didn't help. I plan to pull the wheel off to investigate further. Last time I had the steering wheel off the plastic turn signal switch and posts look brand new.
I don't want to grind some of the metal turn cam off. Do you think some dielectric grease will help lubricate the steering wheel rings, so the post doesn't snag it?
Pictures are just ones I found on the web for reference. Any ideas are appreciated!
