- Aug 27, 2001
- 5,147
Do any of you have this problem that are running Carbs? Every Bronco I have ever had with a V8 ......You have to pump the pedal several times. Start it...then it will die, Pump the pedal again it starts better the second time, but will either die again (usually), or run a little rough. (Even with the choke) Usually the 3rd time..it will start and run pretty good till it warms up. I mean every single Bronco I have had with a 289 or 302 will do this same exact thing. Are they bred this way? Surely from the factory they weren't like this. Then runs fine till you let it sit till the next day. Even does it in the Summer months too. Even my low miles '77 original Ranger will do it and it has the Duraspark ignition. Even all of my fellow Bronco onwers near me have the same problem. What is the cure?
Thanks Much,
Blue71
Thanks Much,
Blue71
