I have had an issue with the upper passenger side ball joint not seating correctly and in the process of diagnosing and fixing it I have installed the knuckle to the axle 4 or 5 times.
Should I be concerned about how many times I have installed and torqued the knuckle. I only pressed the ball joints into the knucle once but have bolted it up multiple times to the axle.
According to the shop manual I need to replace the spindle nuts and lower ball joint nut. Does anyone have a good reason why not to do this.
Thanks, P.J.
Thanks, P.J.
