How much gear oil to fill everything ?
JWMcCrary
Everything has been apart and worked on and needs to be filled. Trying to tally up how much gear oil I need, figured somebody here could make it easy for me. Need to fill the following:
Dana 44
9 inch
NP435
Dana 20 (x2)
SteveL
Huge chevy guy
Hawthorne ca
If you have an old ford truck/bronco manual it should give the quantities. Then buy extra so you can top em off. Don't forget the additive if you have a ls in either diff.
sykanr0ng
The Dana 20 will use different oil than the Ford 9 inch or the Dana 44, the additives for the hypoid gears eat the soft metals in the Dana 20.
Usually 50 weight motor oil is used for the Dana 20.
