Hydroboost mounting bracket
tasker
all knowing of nothing
NH
i have done a few and always use the factory power brake booster bracket...I am sure others will chime in...
Montoya
I took the factory plate and welded it into my thicker firewall plate. I did this because I moved the hydroboost to clear my dumb tall valve covers (non-body-lifted with 351W and roller rockers with tall covers makes everything tight).
Brian B
Brian B
Brian B
Brian B
Thanks to everyone for your input! I'm starting the tear down on Sunday.
tasker
NH
SORRY! looked but these are the best pics I have...used Super duty hydro with 80 Corvette master (4 wheel disc brakes)...work amazing on my other Bronco!
jmhend
What should I buy? Is there one better than the other?
Bryan, as Tasker mentioned the factory angle bracket is perfect for a hydrobost. You can buy an angle bracket and rod from EBAY if you do not have them already.
I also purchased this Early Bronco hydro boost to stock booster bracket 66-77 to just bolt up the astro van hydro to the angle bracket.
https://www.ebay.com/itm/Early-Bron...685548?hash=item4b7868dd6c:g:cj8AAOxyrrpTf1Pq
