Long story, short. PO had an issue with the AT column shifter and installed a B&M. I'm trying to get the shift capability back on the column.
I bought a new tube and a new collar, took it apart and the old ones weren't broken. I'm thinking the welded piece popped out of the shift lever and never went back in.
I can slide the new (and old) tube back into the shift lever without the spring but the spring is making it impossible.
Not sure if there is a trick to it or not but the spring tension (or something) is making this something that I can't figure out. I've watched a few videos on the internet and it doesn't seem that hard to do but something is not working.
I'm wondering if the spring is wrong or if there is a problem further down the line.
Thank you!
Thank you!
