Instrument voltage regulator
400exr1
Hey all,
I've done some reading and think my Ivr is bad. Temp reads about 40 degrees high and oil stays almost pegged. I tried grounding the Ivr to the dash with no luck.
First question, does anyone know of a company who sells an adjustable Ivr? Id like to be able to dial in the gauges.
Also, anyone had any luck adjusting the factory Ivr? I couldn't get needle nose on that little fitting. Any suggestions? Also how much adjustability is there in that factory Ivr?
Thanks so much for all your help. This has been quite a pain.
Blake
Viperwolf1
electron whisperer
Before you go adjusting stuff you need to use some standards. The standard resistance for 1/2 scale reading for temp, oil and fuel gauges is 23 ohms. So, if you put a 23 ohm resistor (1/2 watt) in place of any of those senders you should see 1/2 scale reading on the gauge. I recommend trying all 3 before adjusting anything.
I've seen adjustable electronic IVRs on Ebay. I don't know the range of the stock IVR adjustment.
Bronconaut
Thanks Oleguy for posting that. I need it to fine tune what I've done.
My problem:my temp gauge would read "correct" when you first turned the key on but would then slowly move down to zero over the next few seconds.
Everything checked out. I could ground the wire at the sender and it would peg. I replaced the wire from gauge to the sender, then from IVR (instrument voltage regulator) to gauge, new sender - all the same. All the other gauges worked fine. I happened to have replaced the IVR before I started troubleshooting this. I had also replaced the ammeter with a voltmeter so I connected the IVR output to the voltmeter so I could see the pulse. I was only getting one pulse every 2-3 seconds. I've read on here and elsewhere that it should have been 2 per second.
Rather than spending another $50 or so on a new IVR, I found several schematics and built a digital one using Radio Shack parts. I was then able to adjust the voltage output so the temp gauge "works" - I need to verify temp, oil pressure, etc. now for accuracy but for right now I know what the "ranges" are for normal on each gauge. I was able to adjust the output using the potentiometer from 2-7 volts. Right now I'm having to run it almost at 7 for the temp gauge to work.
Here is the result of my $15 Radio Shack IVR build:
  • Digital IVR.pdf
