I'm using a cheap machinal oil pressure gauge, Sunpro CP8216, so I'm guessing it's between 0-100% good.
Exactly!;D
Might want to check the gauge then too while you're at all this figuring out. I've never tried it, but would not blowing compressed air into the sensor tube net the same results? Leave any oil still in the line, then set your air pressure regulator valve (assuming you have, or can access a compressor?) to a couple of given pressures. Starting at 10psi then going to 20psi and so on.
If your two gauge readings coincide, that's another level of confidence you can have in your gauge.
Your original electrical gauge is not functioning? Could it still be connected temporarily as a quick comparison?
I ran 20w/50 oil for years in my 302. Heavier than recommended, but it's what we had at any given time at the house because it worked in all of our vehicles. That engine had 70psi cold and 40psi hot on the stock gauge. Exactly what the factory manual states is to be expected with our engines. At the end of it's life (with me anyway. I sold it still running) it would go as low as 30psi when hot at idle.
The factory gauge is dampened so does not react to rpm quickly like an aftermarket gauge usually does. Watching the pressure change with rpm you can practically use a mechanical gauge as a tachometer!
Not the same thing with the factory gauge, but in some vehicles it was actually pretty accurate.
