My exhuast was hitting with my M1A1 also. I cut the exhaust back to where it would fit well, then bolted up a James Duff 45° tail pipe ends. Worked good for me.. If you got a tube bender you can cut about 3 inches off the part that's parallel with your tank, then bend the exit back back a few more degrees and weld it back on. Your hanger will have to be moved
I just noticed also, your tank sits alot lower then mine. I've got a 1" body lift...
