- Nov 12, 2011
- 1,321
Thanks. Right now I'd say it's right around the 1" mark. I tried to reference many measurements from my Bronco with the 1" body lift as I was figuring things out. The biggest issue is the front floor section as it sits almost 1" lower than the rest of the floors and also as compared to a factory tub, so with the 1" body lift you end up needing basically a stock sized mount, maybe with a spacer or two, under each front floor pan.Looking good. I have the same body, never installed. What do you figure the body lift will end up being? I was contemplating doing the same thing with sub-structure to tie the cage and seats into. Maybe rockers too.
