rebuilt my column shift with new thrust washers and spacer, while I was at it removed the lower steering shaft, which turns out to be some kind of hybrid 2 piece shaft with tulip/bell-shaped coupler at the steering box.
Cleaned up and greased the lower shaft unit, put everything back together and now the entire steering shaft, upper and lower, moves about an inch back and forth. In other words the back and forth movement inside the tulip can be felt at the wheel.
The pic with lower unit removed is before, other pic is after.
There is a groove in the shaft (2nd pic) that looks like it should have a clip on it to keep it behind the lower column bearing? If so does this keep it from moving in EITHER direction?
I believe the column itself to be a 76-77 version...like i said hybrid...I've now named my 72 Frankie because of all the different crap she's made of ?:? any help appreciated -Jeff
