I have a slight stumble with my EFI 302 between idle and 1500 RPM. Throttle tip-in in this range gives a little bit of hesitation or stumble. What’s odd is that it only happens with slight throttle, if you stab the skinny pedal down low there’s no stumble. I can replicate this problem since I have a manual transmission by running a gear down below 1500 rpm then tipping in the throttle (maybe 10-20% ). Depending on which gear and how much load is on the motor, it can produce some bucking/pinging which is a clear sign of too much timing advance and detonation! The issue is easily avoidable as I don't make a habit of lugging around my MT gears below 1500 RPM.
So my question; without getting into EEC tuning can I manually adjust the initial base timing to work around this issue? I’m current set at 10 degree BTDC and the EEC is operating correctly with full range of an additional 20 degree advance (tested).
My motor setup is nothing crazy but it’s possible the EEC might need tuning due to the cam used. I don’t have the engine specs but I know it’s a flat-tappet cam and is clearly aftermarket in performance (rumppty rump) ;D
Thoughts?
Thoughts?
