I'm still running that setup on my Bronco. As was said, the parking brake is crap just like the caddy calipers. The calipers interfere with the stock rear shock mounts, so you need to make a new mount or swap the calipers side to side. If you swap them side to side, it makes it even more difficult to hook up the parking brake.
The caliper mounting brackets double as the bearing retainer, so you either have to have the bearings pressed off to install the bracket or notch them to slide over. The rotors won't fit over stock axle flanges, so you need to have the flanges turned down. As was said, the Lincoln is 5x5 bolt pattern, so you need to have the rotors re-drilled to 5x5.5 pattern.
Quite a bit of work for little gain. I plan on ditching mine one of these days and just going back to the stock 11" drums.
