hammer189
Need opinion on the gear pattern please.
Once gear pattern is considered "good" I need help finishing assembly.
How to set final carrier preload without a torque wrench for ring adjusters?
1 hole farther, 2? Try for a certain total preload on the pinion when everything is assembled?
New yukon gears 4.56
New truetrac differential.
Pinion preload 15" lbs, 20"lbs completely assembled with seal etc.
Runout on ring gear .002"
Backlash .011 with light carrier preload.
Went 1 hole further with ring adjuster.
Pinion preload with carier installed is now 23-24 "lbs.
Thanks for the help. This is my first attempt at working on the rear end gears. David
