My 72 302 has its PCV valve hose running from the drivers side to the vacuum block on the back of the engine.
I'm glad you're replacing it. It should NEVER run to a port or block in one single intake runner. It should ALWAYS go to a common area under the carb. That's why the original was there.
Most Holley carbs have a 3/8" hose barb either coming out of one side, or an end. Usually a side on the ones I've seen.
Do you have power brakes? If so, is the brake hose going to the carb? If so, those two need to be switched around. A brake booster can go to a single intake runner while the PCV has to go to the plenum.
I want to replace the hose but not sure what I need. Think these usually ran from the cover to carb port. Since mine is a Holley 4 barrel with ford performance intake it’s a different setup.
Yep, the original was a molded hose with two different sized ends. Yours is a replacement and like was said I too think it's just an old piece of fuel line that has been there long enough to be set in it's ways, so to speak. At least that's what it looks like from here.
Aftermarket manifolds often don't have the fittings we need, but if you have that one single port on the carb mentioned previously you should be good to go.
I like bending my own out of the 3/8" tubing that was mentioned as well, and using rubber only at the ends.
The hose that’s on it is an Autolite but doesn’t have a part number so I’m not sure what I need.
Might have been a donor from the junk yard. Might have been new at one time bought from a dealer or supplier, but it's just generic hose looks like from here.
At least someone appears to have used good quality hose. It just can't last forever even when you use the good stuff anymore.
paul
