.. So I HAVE A 1980 OJ BRONCO I've had since 1986. I bought it out of the wrecking yard . & It's had 3 motors put into it. It has 386K ON IT .
... So I've traded for a 1995 300 cid EFI . I got motor & 5 speed trans & radiator & all the wiring harness & Computer .
... SO My question before we get started .. DO YOU KNOW IF THE 1995 300 BLOCK HAS THE SAME BOLT PATERN FOR THE BELL HOUSING AS THE OLD 1980 HAD. & Will the flywheel from the 80 fit the crank on the 95 300.
... I want to use the 80 bell housing & clutch set up . I don't want to have to swap over to the hyd clutch.
... I'm hoping I can start about april.
